I got an assembly where the UCS doesnt match the ground plane
Can I adjust the UCS so it match the groundplane?
When I import this file to "showcase" I cant get it correct aligned with the ground due to this UCS twist
Solved by JDMather. Go to Solution.
Is one of the parts Grounded?
Right click on the Grounded part and un-ground it.
Add Mate-Flush between the part's XY, YZ, XZ and the assembly origin planes (add an offset if desired).
