I need to do so because the dwg can take up to 30 seconds to open if i use the master LOD but when i use a stripped down LOD it loads in about 5 seconds.
So, i want the drawing view to be saved using the stripped down LoD and after the dwg opens, change the LoD to master.
How can I achieve this? I searched a lot but i couldn't find any solution. Thank you for your time!
are you doing some API coding and need to add this additional functionality then?
(yes we are talking about a dwg file)
Well I had thought of that too, but no. I think that the loading time wont be the same. In a test I did, I saved the dwg document with the views being at another LoD witch has much less detail and when I tried to open it, the loading time plus the time i takes for it's iLogic rule to run, took about 15 sec less than the time it takes for the same amount of work at the same machine with toe Lod of the views set to the LoD of maximum detail.....
