When I boot Inventor 2015 I get this screen display.
Can I get rid of, or at least minimize, the gray block on the left?
Solved by rickduley. Go to Solution.
Hi Rick,
try this:
Admaiora
That holds the answer.
To clarify, from trying this out, :
1. Uncheck "Startup Action", then
2. Check "Show MyHome on startup"
Then it works. Having both checked (understandably) confuses Inventor.
