Inventor Forum
Changing Templates in a file?
3 REPLIES 3
201 Views, 3 Replies
I created a sketch in a file using a standard.ipt Template and I should have
used a Sheet metal.ipt template. So, now I can't access the Style and Face
tools on the Sheet metal Panel Bar. Is there a way to exchange Templates in
a file? Thanks, Bob
3 REPLIES 3
Choose Application/Sheet Metal, then you get all the commands.
/Janne
"Bob Johnson" skrev i meddelandet
news:A5C50EFE16D578ECD96F22FB0FE01101@in.WebX.maYIadrTaRb...
have
Face
in
> a file? Thanks, Bob
Applications > Sheet Metal
Dennis
> a file? Thanks, Bob
Dennis Jeffrey
CAD Associates - Fort Wayne
Autodesk University Instructor
Autodesk ASC
(260-432-9695 x 221
If you have some things such as materials setup in your sheetmetal template
and you have only done one sketch, it may be worth it to start a new part
using the right template, and then copy the sketch and paste it in the new
ipt file.
Otherwise do as the others suggested.
Kent Keller
Member of the Autodesk Discussion Forum Moderator Program
http://www.MyMcad.com/KWiK/Mcad.htm
"Bob Johnson" wrote in message
have
Face
in
> a file? Thanks, Bob
