If you have some things such as materials setup in your sheetmetal template
and you have only done one sketch, it may be worth it to start a new part
using the right template, and then copy the sketch and paste it in the new
ipt file.
Otherwise do as the others suggested.
Kent Keller
Member of the Autodesk Discussion Forum Moderator Program
http://www.MyMcad.com/KWiK/Mcad.htm
"Bob Johnson" wrote in message
news:A5C50EFE16D578ECD96F22FB0FE01101@in.WebX.maYIadrTaRb...
> I created a sketch in a file using a standard.ipt Template and I should
have
> used a Sheet metal.ipt template. So, now I can't access the Style and
Face
> tools on the Sheet metal Panel Bar. Is there a way to exchange Templates
in
> a file? Thanks, Bob
