I am very much a beginner in learning how to write rules in iLogic.
I have a wooden part
I want to create a list of stain options in my parameters.
When i click on a stain color in that list, i want my wooden part to change stain, and tint. I'm coming up with with the RGB numbers that match my stains.
I need help with the logic that makes the stain change colors and linking that to my parameter list of stains. Help is much appericiated. Thank you
Solved by mcgyvr. Go to Solution.
I have tried to write my own logic rules to accomplish this but I don't seem to be ever headed in the write direction.
Can't help with the ilogic..
Should be fairly simple to have a form that can change the appearance of a part..
BUT I would accomplish that with an ipart and not bother with ilogic.
I would assume that when the stain changes colors so does this wooden parts part number.
(For stocking/inventory reasons I would always recommend a different finish gets a different part number)
Its easy to setup all your different appearances then create an ipart and change the appearance there..
Create your ipart family and you are done.
I don't see the need to use ilogic for something like that unless you expect to be able to create new appearances on the fly.
I would expect you only have a few stain colors that are always used so its just a matter of setting them up once and done.
