Inventor Forum
Changing Sketch Origin
5 REPLIES 5
SteveFrey
444 Views, 5 Replies
How do I change the origin of the sketch on the attached .ipt?  If you open the .ipt and click on the FRONT tab of the view box, you can see that sketch 2 is showing face forwards (FRONT), where I want it to be.  If you double click Sketch 2 you wind up seeing it upside down.  How do I change this so it stays facing the same direction when I go to edit it?
Steve Frey
Inventor 2021
Windows 10 Professional 64-bit
HP ZBook 17 G6
Processor: Intel(R) Core(TM) i9-9880H CPU @ 2.30GHz
Memory: 80 GB
NVIDIA Quadro RTX5000
3D Connexion SpaceMouse Wireless
5 REPLIES 5
mdavis22569
in reply to: SteveFrey
I think this is what your asking about ... Go to Options ... Sketch Tab and see if the Look at Sketch Plane on Sketch Creation is Checked ... if so uncheck it and try the model now
Mike Davis
SteveFrey
in reply to: mdavis22569
Thanks.  That worked.  Is there a way that the sketch plane can position so I am looking at the sketch I clicked on?  Say I click on the front view, I'd like it to look at the front view so I can work on the sketch without it being skewed.
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
rdyson
Look At (on the Nav Bar) or Page Up (keyboard) and then click a sketch element
PDSU 2016
SteveFrey
in reply to: rdyson
I thought I remembered this doing it by itself when I clicked the sketch.
Steve Frey
Inventor 2021
HP ZBook 17 G6
Memory: 80 GB
rdyson
I'm pretty sure it's controlled by Ap Option > Sketch >Look at sketch oh creation and edit.
PDSU 2016
