How do I change the origin of the sketch on the attached .ipt? If you open the .ipt and click on the FRONT tab of the view box, you can see that sketch 2 is showing face forwards (FRONT), where I want it to be. If you double click Sketch 2 you wind up seeing it upside down. How do I change this so it stays facing the same direction when I go to edit it?
Solved by mdavis22569. Go to Solution.
Thanks. That worked. Is there a way that the sketch plane can position so I am looking at the sketch I clicked on? Say I click on the front view, I'd like it to look at the front view so I can work on the sketch without it being skewed.
I thought I remembered this doing it by itself when I clicked the sketch.
