I wondered if there is a way of changing view reference from one object to another.
Example.
I have two similar models but drawing done for one.
I could save it as with a different name and replace in all the views referenciing from old model to new one.
Possible?
Solved by harco. Go to Solution.
Yes,for versions 2010 and newer.
Have a look here
Procedures
+Replace model references in drawings
Wikihelp says no.
"NoteYou can replace a model only with the same type of model. Replace IPT with IPT, IAM with IAM, and IPN with IPN."
But have a go, you never know.
I bet your dimensions will get messed up if it does work as the edges will not be recognised.
