Inventor Forum
Changing reference object in drawing file
3 REPLIES 3
Infoseeker
451 Views, 3 Replies
I wondered if there is a way of changing view reference from one object to another.
Example.
I have two similar models but drawing done for one.
I could save it as with a different name and replace in all the views referenciing from old model to new one.
Possible?
3 REPLIES 3
harco
in reply to: Infoseeker
Yes,for versions 2010 and newer.
Have a look here
Procedures
   +Replace model references in drawings
Infoseeker
in reply to: harco
Thanks.
Can the .iam references be changed in .ipt file?
harco
Wikihelp says no.
"NoteYou can replace a model only with the same type of model. Replace IPT with IPT, IAM with IAM, and IPN with IPN."
But have a go, you never know.
I bet your dimensions will get messed up if it does work as the edges will not be recognised.
