Inventor Forum
Changing Radius Dimension to Diameter
18 REPLIES 18
Message 1 of 19
Cadmanto
49297 Views, 18 Replies
How do I change this dimension into a diameter dimension?
I have tried editing the dimension style to display as a diameter and it doesn't change it.  I tried creating a new dimension style and it doesn't change it.  So thus the question.
Best Regards,
Scott McFadden
(Colossians 3:23-25)
18 REPLIES 18
Message 2 of 19
Hi Cadmanto,
If you right-click while creating the dimension (select the curve, then right click), you can toggle it to a diameter dimension.
Will that work?
I hope this helps.
Curtis
Message 3 of 19
Yes, that will and did work quite nicely!!!  Smiley Happy
Thank you.
So why can't it be changed after it is created?  Is this a bug in the software?
Best Regards,
Scott McFadden
Message 4 of 19
Hi Cadmanto,
Not a bug since it's functioning "as designed", but it's certainly a limitation.
I know you're aware of feature enchancement link, but I'm posting this in case someone else sees this and thinks it would be a good idea too.
http://inventortrenches.blogspot.com/2011/01/feature-request-for-inventor.html
I hope this helps.
Curtis
Message 5 of 19
Hey Curtis,
Ok, fair enough.
Yes, I know of that link thanks to you and I think I will suggest this as
an enhancement.
Best Regards,
Scott McFadden
Message 6 of 19
I select the curve and right click I do not get the option to change it to a diameter. I get properties and visibility and zoom. I really want to change this.
Message 7 of 19
Hi nwrensch,
Start the Dimension tool, click the circle/arc, and THEN right click.
Make sure you're not clicking a mid point (green dot) or something else. The arc/circle will highlight when you've clicked it.
Also make sure you have only the arc/circle selected, as that might give you different right click results if you have more than just the intended geometry selected.
I hope this helps.
Curtis
Message 8 of 19
I still didn't work, I still was not given an option to change the
dimension type. I am using Inventor 2017 release 2017.3
Norm Wrensch
Manufacturing Engineer
MPI Products LLC
101 Grand Ave.
Deerfield, WI 53531
Phone: 608.764.5416 ext, 114
Fax: 608.764.8408
nwrensch@mpiproducts.com
www.mpi-int.com
Message 9 of 19
Hi nwrensch,
Not much more to be done from this end but guess, so let's start at the beginning:
Is your computer plugged in?
Is Inventor started?
Do you have a drawing open?
Is there a circle or arc on the drawing?
Smiley Tongue
I'm just joking, but you'll have to provide more than "it's not working" in order to go further.
Can you attach some screen shots, or describe the steps you are taking exactly? Are you trying to modify an existing dimension (that can't be done as noted by Cadmanto), or are you creating a new dimension?
More info please.
I hope this helps.
Curtis
Message 10 of 19
JDMather
in reply to: nwrensch
Can you attach an example file here that doesn't work?
Is the geometry an arc or is the geometry a spline?
Can you make a Screencast Recording of your steps?
Message 11 of 19
tis07282015
in reply to: JDMather
Screen shot file is attached.
for right most geometry option to diameter worked, did not work for any other arcs.
Sudhir
Message 12 of 19
johnsonshiue
in reply to: tis07282015
Hi Sudhir,
It is possible the arc is not true arc. It is a spline looking like an arc. Try this. Go to the model and use Measure command of measure the same edge. Does it show radius/diameter value? If yes, I would like to see the example. Please share it here or send it to me directly (johnson.shiue@autodesk.com).
Many thanks!
Software Test Engineer
Message 13 of 19
nigel_swehla
in reply to: johnsonshiue
Using Autodesk Inventor 2017 Professional.
Message 14 of 19
Hi @nigel_swehla
Welcome to the forum.
Once the dimension has been placed the type can not be changed. Not sure why, but that is how it works/doesn't work.
It is as you are placing the dimension that you must right click, and choose Dimension Type in order to change the type.
I hope this helps.
Curtis
Message 15 of 19
dnssaw1
in reply to: Cadmanto
It helped me, thank you so much I've been looking for an hour
Message 16 of 19
RAMLago
in reply to: dnssaw1
Hello to everyone,
I have one question, this situation is possible to apply in the baseline dimension?
I have a cylinder and i made a section of one side only, and i want to put 10 or 20 dimensions using the baseline command, but i want that dimensions as a diameter.
There is any way to do that using baseline? or i have to put one dimension at the time?
Thanks for the time!
Message 17 of 19
Curtis_Waguespack
in reply to: RAMLago
Hi @RAMLago
I don't know of a solution for this, but here is a link to a future enhancement request that is similar:
https://forums.autodesk.com/t5/inventor-ideas/angular-ordinate-dimensions/idi-p/5252263
Feel free to add your feedback at that link if you have additional thoughts.
I hope this helps.
Curtis
Message 18 of 19
Thank you guys it solved my problem.
@Curtis_Waguespack wrote:
Hi nwrensch,
I hope this helps.
Curtis
Message 19 of 19
@Curtis_Waguespack Thanks for your video. I can change the radius dimension to diameter dimension now.
