Inventor General Discussion
Cadmanto
Message 1 of 5 (2,331 Views)
Changing Radius Dimension to Diameter
2331 Views, 4 Replies
07-09-2012 09:16 AM
How do I change this dimension into a diameter dimension?
I have tried editing the dimension style to display as a diameter and it doesn't change it.  I tried creating a new dimension style and it doesn't change it.  So thus the question.
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
Hi Cadmanto,
If you right-click while creating the dimension (select the curve, then right click), you can toggle it to a diameter dimension.
Will that work?
I hope this helps.
Curtis
Curtis_Waguespack
Message 2 of 5 (2,329 Views)
Re: Changing Radius Dimension to Diameter
07-09-2012 09:17 AM in reply to: Cadmanto
Hi Cadmanto,
Will that work?
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Cadmanto
Message 3 of 5 (2,324 Views)
07-09-2012 09:21 AM in reply to: Curtis_Waguespack
Yes, that will and did work quite nicely!!!  :smileyhappy:
Thank you.
So why can't it be changed after it is created?  Is this a bug in the software?
Best Regards,
Scott McFadden
Curtis_Waguespack
Message 4 of 5 (2,320 Views)
07-09-2012 09:26 AM in reply to: Cadmanto
Hi Cadmanto,
Not a bug since it's functioning "as designed", but it's certainly a limitation.
I know you're aware of feature enchancement link, but I'm posting this in case someone else sees this and thinks it would be a good idea too.
http://inventortrenches.blogspot.com/2011/01/feature-request-for-inventor.html
I hope this helps.
Curtis
Cadmanto
Message 5 of 5 (2,318 Views)
07-09-2012 09:29 AM in reply to: Curtis_Waguespack
Hey Curtis,
Ok, fair enough.
Yes, I know of that link thanks to you and I think I will suggest this as
an enhancement.
Best Regards,
Scott McFadden
