Is there a standard command or command sequence that allows for the changing of a parameter, say length, of a component from within an assembly. I'm looking to compile a code that allows for a template to be created, then that template will do changes based on text box input and then save out the modified parts with new part numbers.
Solved by cwhetten. Go to Solution.
Hi and welcome to the forum!
This is easily done as follows:
Post back if you have any more questions.
Cameron Whetten
Inventor 2012
Please click "Accept as Solution" if this response answers your question.
