I have an assembly of 23 parts.
I want to change the 23 file namesI but do not want to create this assembly again.
Can i change the file names of the 23 individual parts in an assembly file already saved/created without having to re-create the assembly file?
Solved by blair. Go to Solution.
If you are using Vault, it can be done within Vault, if not, then use the Design Assistant. There should be a video or two on Youtube as well as the Autodesk Chronicle website.
