Hello, I was wondering how do I change the order of attributes in my IDW titleblock. This would be the order in which they are filled in, when completing the titleblock info. I know in AutoCAD, it depends on the order you select the attributes, but what determines it in Inventor?
Thanks in advance
Solved by mcgyvr. Go to Solution.
Kevin,
This depends entirely on what your Titleblock looks like... what information do you have in it, and where are you pulling it from? If you're filling it from iproperties, or prompted entry text etc.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
