Inventor General Discussion
Active Contributor
robert2445
Message 1 of 2 (145 Views)
Changing material in a design accelerator part (shaft generator)
145 Views, 1 Replies
04-01-2010 11:23 AM
The default material for generating the shaft is steel. How do I change the material to Aluminum??
**Master
BMiller63
Message 2 of 2 (145 Views)
Re: Changing material in a design accelerator part (shaft generator)
04-01-2010 12:24 PM in reply to: robert2445
there is a material check box in the calculation tab, set it there for the calcs, then edit the part file for the shaft. keep in mind the shaft generator outputs an assembly file containing the shaft ipt, so you have to drill down.
