Inventor Forum
Changing material in a design accelerator part (shaft generator)
1 REPLY 1
417 Views, 1 Reply
The default material for generating the shaft is steel. How do I change the material to Aluminum??
1 REPLY 1
there is a material check box in the calculation tab, set it there for the calcs, then edit the part file for the shaft. keep in mind the shaft generator outputs an assembly file containing the shaft ipt, so you have to drill down.
