Show only
Search instead for
Changing material in a design accelerator part (shaft generator)
there is a material check box in the calculation tab, set it there for the calcs, then edit the part file for the shaft. keep in mind the shaft generator outputs an assembly file containing the shaft ipt, so you have to drill down.
