Solved by mlynch5ZCFL. Go to Solution.
Grettings!
How can I do that? When I select a view, is not possible to apply the desired standard.
Thanks!
I also am looking for this 12 years later. Does anyone know how to apply a standard to existing drawing views?
Responding to myself, I found that you can replace the current drawing standard in the style editor. This however only works on the active sheet. Better but still not a good solution.
Link to the code that eventually worked: Replace Styles and Standards in a drawing using iLogic - Autodesk Community - Inventor
