Inventor General Discussion
Valued Contributor
danielw88
Message 1 of 3 (360 Views)
changing dimension text size
360 Views, 2 Replies
11-25-2011 09:07 AM
I have been working on some spec sheets and, ideally, would like the text size larger to improve readability. When creating text, changing the size is as easy as editing the text and changing the size. With a dimension, however, that method doesn't work. Is there an easy way to change a dimension's text size without having to make a change in the styles??
Employee
t_pcoll
Message 2 of 3 (318 Views)
Re: changing dimension text size
12-07-2011 05:47 AM in reply to: danielw88
Hi, text overrides other then color and stretch are not supported. There was a WISH item logged already (DID#737120). I have added your comments to the defect.
Ladislav
*Expert Elite*
jtylerbc
Message 3 of 3 (313 Views)
12-07-2011 06:00 AM in reply to: danielw88
I know you were trying to do this without messing with styles, but it sounds to me like that is exactly what you should do anyway.
Create a new dimension style for "Spec Sheet Dims" and a corresponding text style if needed, then you'll have it available for future spec sheets.  Even if it was possible, opening each dimension and manually changing the text size would be a lot more work than just changing the dimension style would be.
John Tyler
Inventor 2015
Windows 7 64 Bit
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
