I want to changed the default visible line weight for all drawings. I just can't get it to work. I have changed my project file settings to "Read-Write", I have tried this in both the Default Standard and my own standard. I changed the "Visible (ANSI)" Line Weight, saved it, then hit "Save" on the Styles and Standards bar. It works for a document. But when I open a new document, the line weight has reverted back to the old value.
Solved by dano0310. Go to Solution.
When you save anything to the styles you first have to make sure that your master project file is read/write.
Then when you have your settings set in the styles library select this button.
After you are done change your master project file back to read only.
Hope this helps you.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
I changed the Read-Write back to Read-Only. Then I opened a new file and it still did not have the correct values.
Ah, I think I just needed to update the drawings. I thought it would have done it automatically. I think I'm good.
