Inventor Forum
Changing coordinate system direction
5 REPLIES 5
453 Views, 5 Replies
I know this has been asked before, because I remember reading something about it.
I just can't find it anywhere.
When I start a new drawing or assembly, can I set up the coordinate
system or indicator so that "Z" in pointing up?
-Ken
5 REPLIES 5
1/ Select the Rotate tool
2/ Free rotate the part until the axes are roughly the way you want them
3/ Hit the space bare to show the common views cube
4/ Select the corner nearest you to fine tune the alignment
5/ RMB and select Redefine Isometric
6/ save as your template
Unfortunately, in the idw environment, the axis setting doesn't follow
through so you have to get used to the front view being the top and the
bottom view being front and so on.
Richard
> Thanks,
> -Ken
Do you mean that the new sketch should be on the YZ plane instead of XY?
If so, Tools > Applications Options
Go to the Part tab
Select Sketch on Y-Z plane
HTH
Rory
"Ken Schumacher" wrote in message
news:0C5BB87C9A8152A2DCC16CCA34923C06@in.WebX.maYIadrTaRb...
about it.
> Thanks,
> -Ken
Tools>> App options>> Part>> Change the sketch on New Part Creation to suite.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
> Thanks,
> -Ken
Thanks for the replies.
I meant I wanted to change the default when I start a new drawing.
I guess Richard's approach is what I'm going to have to deal with.
Thanks again.
"Kent Keller" wrote in message news:5A4943A31CFB2B1196A72485790A41A8@in.WebX.maYIadrTaRb...
> Kent
> Assistant Moderator
> > Thanks,
> > -Ken
Can I use a flat sheet metal pattern view as a sketch and modify it by
adding match marks and tabs ?
Bob
