A couple of quick questions:
1) Once a construction centerline is placed and constrained can you switch it to just a regular centerline?
2) Can you change a regular line to a construction line?
3) Can you change a construction line to a centerline?
I guess what I am asking is can you change line types at all ones they are placed?
Solved by JDMather. Go to Solution.
1. yes
2. yes
3. yes
See upper right corner of your Sketch screen for the toggles.
