Inventor Forum
Changing C/C component Automation
43 REPLIES 43
Message 1 of 44
shannonadmin
7717 Views, 43 Replies
I'm looking at creating some Parametric models with Excel and ilogic
Anyone know if it’s possible to automate the changing of content centre components parts in a model using ilogic or some other method other than the traditional way of  manually selecting the components in the assembly followed by right mouse click to change
 As an example let say my model has some 1/2" hex bolts and I want to change them to 3/4" Hex Bolts is there a way to change these though a front end interface like and excel spreadsheet? or ilogic?
 N_M
43 REPLIES 43
Message 41 of 44
jsmith923
in reply to: MjDeck
Mike,
Is it possible to Replace All of one length like with the normal Component.Replace command?  I have the code working for me for one component at a time, but it would save time if I could replace all components of the same length with the new length.
Jeremy Smith
Steel King Ind. Inc.
Message 42 of 44
Hi All,
Kindly find the simplified code based on the below link
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/iLogic-place-Structural-Shapes-Channel...
Updated Ilogic-content center-1.iam to handle both  "Standard" as well as "Custom" CC handling in Grabcad Website
Do visit http://grabcad.com/library/ilogic-content-center-1
to download the example file based on the above link
Message 43 of 44
in reply to: jsmith923
I'm currently working on automating the switch between Steel and Stainless Steel of Content Center items for a customer and was also looking for a 'Replace All' command.
Message 44 of 44
Hi Mike
Is there a way to get the values from a column in the content centre and populate a multi value parameter to then use in a form for selecting the options?
