Hi. Im having problems figuring out how to change the the appearance of indivitual copied object when using the pattern tool. I can change the appearance on the original object (which is red on the picture) but im having problem changing the the appearance of the other objects ( i want all of them to have different colors)
If anyone could help it would be much appreciated. Thanks
jeanchile is right - just expand the Component Pattern Element, select the component(s), then change its appearance.
Remember that it's an assembly-level colour override, so you would be advised to create a View Rep to manage it.
Peter
