I have 2 content centre parts i would like to alter.
How do i change the parameters so both the Nut and Bolt Chamfer-1 are 16mm diagonally across instead of 18mm.....i want the face to not touch the edge
I tried changing the parameters (fx) and on the tree but could not get it to change corectly
The 2 CC attached are 2013
Thank...Simon
Solved by salariua. Go to Solution.
Solved by SBix26. Go to Solution.
What parameter(s) did you try to change? In the nut, if you look at the sketch for the Chamfer 1 feature, you see that the controlling parameters are SW0 & SW01. In the parameters dialog, you find that both of these are set equal to parameter SW, which is the width across flats, = 18 mm. Simply set SW0 & SW01 both = 16 mm instead of = SW. I didn't look at the bolt, but it would likely be similar. Just track back through the parameters and see which parameters control which features.
Sam B
Inventor 2012 Certified Professional
Inventor Professional 2015 SP1
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
Question is : Do you want to change content center family or just these two parts?
If just these parts you want and you need to keep the width across flats standard then edit the chamfer revolve sketch and change dimension to 16.
