Inventor Forum
Change Units in an IDW
2 REPLIES 2
wilson12
4908 Views, 2 Replies
I created an idw and annotated all the dimensions in default to inches. Is it possible to switch all of the units from inches to mm at one time? If so, how?
2 REPLIES 2
Cadmanto
in reply to: wilson12
Maybe through iLogic.
Once you have placed dimensions the only way to change them would be to tag them all and RC and select "New dimension style" and change them that way.
The styles are setup through the template you choose.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Hi wilson12,
In the IDW, hold the Shift key and then right-click and choose Select All Inventor Dimensions, then go to the Annotate tab and look for the Style drop down box, there you should be able to choose a mm based dimension style assuming one exists. If you don't have a mm dimension style, you would need to create one first.
I hope this helps.
Curtis
