When you make a drawing, the name og the drawing will get the name of the first view you place in the drawing.
Sometimes I make a second sheet with only some different parts in scale 1:1 for cutting the steel plates on a machine what uses the drawing as a guide line. I want the name of the second sheet the same as sheet 1. So I place first the assembly outside the drawing to get the right name on sheet 2 and place the parts later.
I often forget to place the assembly first, so I get a wrong name on sheet 2.
Is there a method to change the sheet name to an other later placed view?
Rob
You can always rename a sheet simply by two slow clicks.
I would assume he has to be talking about what shows in the title block not the name of the sheet in the browser. I would like a way to change what is the first view as well.
@coreyparks wrote:.... what shows in the title block ...
Ah, I missed any mention of the title block in his problem description. Makes more sense now.
" I want the name of the second sheet the same as sheet 1" seemed too obvious.
