Inventor Forum
change sheet metal parts material, thickness Bend Radii from assembly.
3 REPLIES 3
830 Views, 3 Replies
How do we change sheet metal parts material, thickness Bend Radii from an assembly in groups
3 REPLIES 3
BarryZA
Other than campaigning for multi-body solids for sheet metal I don't know.
pcrawley
in reply to: BarryZA
iLogic.  If all your SM parts contain the required Sheet Metal Style, it should be fairly straightforward.  Otherwise you just run through each part, check it's sheet metal, then change the appropriate parameters.
Add my name to the Sheet Metal multi-body campaign... Or here's a better idea, add your name to the existing Idea Station post: http://forums.autodesk.com/t5/Inventor-IdeaStation/Sheet-metal-Multibody/idi-p/3743397
Peter
4donwan4
Just seconding the comment by Peter. As for the out of box install the files would need to be changed on a 1 by 1 basis as there is no application or routine to run this type of edit for a group. This would be something useful, consider adding an enhancement request at the below link.
Don
