Inventor General Discussion
Active Member
texteditor
Message 1 of 8 (1,036 Views)
Change part reference in drawing
1036 Views, 7 Replies
02-02-2013 04:01 AM
In solidworks, if I have several similar parts to draw, I can draw one part and annotate it and then to save time and effort I can save the drawing as one of the other parts and then change the part reference in the drawing as I open it up.
Is this possible in Inventor?
Thanks texteditor.
Doesn't Manage>Modify>Replace Model Reference do the same thing?
Active Member
gjohnston
Message 2 of 8 (1,035 Views)
Re: Change part reference in drawing
02-02-2013 04:03 AM in reply to: texteditor
I do this often. Open ipt then save as new part.
Active Member
texteditor
Message 3 of 8 (1,020 Views)
02-02-2013 07:20 AM in reply to: gjohnston
Sorry not clear enogh in my explanation - in solidworks have 2 similar parts and do drawing of one with all sorts of views and annotations.
Then save drawing as drawing of second part and change reference in drawing to refer to second part _ drawing then opens up with similar drawing to first part but with all the views containing and referencing second part.
texteditor
Active Member
gjohnston
Message 4 of 8 (1,015 Views)
02-02-2013 08:21 AM in reply to: texteditor
Not that I know of. Sounds like a good idea. I'd vote for that. Have a nice day. Gerry
Distinguished Mentor
rdyson
Message 5 of 8 (1,009 Views)
02-02-2013 09:48 AM in reply to: gjohnston
Active Member
gjohnston
Message 6 of 8 (1,005 Views)
02-02-2013 10:04 AM in reply to: rdyson
I did not know that was there. Thank you so much. That should make my life easier. Have a nice day. Gerry
IgorMir
Message 7 of 8 (999 Views)
02-02-2013 04:38 PM in reply to: texteditor
Using iParts will get you what you are after.
Best Regards,
Igor.
Web: www.meqc.com.au
Active Member
texteditor
Message 8 of 8 (984 Views)
02-03-2013 09:52 AM in reply to: rdyson
Exactly what I wanted.
Thanks texteditor.
