In solidworks, if I have several similar parts to draw, I can draw one part and annotate it and then to save time and effort I can save the drawing as one of the other parts and then change the part reference in the drawing as I open it up.
Is this possible in Inventor?
Thanks texteditor.
Solved by rdyson. Go to Solution.
Sorry not clear enogh in my explanation - in solidworks have 2 similar parts and do drawing of one with all sorts of views and annotations.
Then save drawing as drawing of second part and change reference in drawing to refer to second part _ drawing then opens up with similar drawing to first part but with all the views containing and referencing second part.
texteditor
Using iParts will get you what you are after.
Best Regards,
Igor.
