Paul
I am no expert in this area, but in the case you are talking about... just one IDW and its
IPT you should just be able to use Windows to copy the files to the new directory (as long
as both directories aren't in the Project files)
Make sure the Project for the new location is active, Exit Inventor then In the new
location in Windows Explorer and rmb on the IDW and choose Design assistant. Go to Manage
mode, and click on Action for the IPT file. Choose Rename, then Right click on its name
in the Name column and choose change name. Enter the new name and click Open. Then
click the Save
button and exit DA. Now in Windows just rename the IDW file.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Paul Houlker" <666paulh@rimex.com666> wrote in message
news:05108E9ED5FFB4592C03994C032CE915@in.WebX.maYIadrTaRb...
> I have two files. (Under project Bead Breaker Clamps.ipj)
> G:\Engineering Dwgs\Projects\2492\Bead Breaker Clamps\2492-10.Idw
> G:\Engineering Dwgs\Projects\2492\Bead Breaker Clamps\2492-10.Ipt
> I need to move & rename them to (Under project Rimex Inventor.ipj)
> G:\Dwgs\00\Inventor\785-000-0009.Idw
> G:\Dwgs\00\Inventor\785-000-0009.Ipt
> I had a few posts about this last week, every thing I tried has resulted in
> corrupt files or it all seems to work, but when I open the new files and
> hit save i get "Problems encountered while saving the document".
> Could someone give me detailed step by step instuctions please. That way I
> can check If I am missing something. All help is welcome, I am getting
> desperate here.
> Thanks
