I have a question.
In Inventor 2013 it was easily to switch in a drawing view between different iPart members. Through Edit view => Tab Model State and then it was possible to switch between different iPart members. So it was easy to make a copy in the Vault from only the dwg (from a iPart member) and then change the iPart member. Now in Inventor 2014 it is not possible anymore.
I'm looking forward to your answer.
Jorn van Vliet
I have maked a video of the problem, so maybe than it is more clearer: http://we.tl/I5XnHYs3ci.
Regard,
Jorn
Jorn,
Is it fair to say that the ipart member are regenerated so they would show up in the drawing edit display dialog window?
Are you using vault? Are all of the members checkout with you having ownership of them?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Hi! What R2014 build are you on? Have you applied SP1 and Update2? I vaguely remembered it was resolved in one of the patches.
Thanks!
