So, I have built our pipes in different runs and routes under our main Tube and Pipe Assembly. On the main Pipe assembly I'm able to change to different LOD to remove Valves and Gaskets, but not on the lower level runs.
The purpose of doing this is to be able to create drawings on every run without gaskets and valves, but as of now the only option i have is to supress these items on every sheet and I'm guessing there is a better way.
So if anyone has som input i would be grateful.
Solved by mdavis22569. Go to Solution.
Mike,
Thanks i used supress in my Run assemblies and couldn't save the changes, but now when creating View instead of Detail, and visibility instead of supress it works thanks.
