Hi, Is there a way to change Frame Generator profiles using iLogic by way of a form without suppresing/unsuppressing?
e.g. I have a frame that is 50x50x2 and using an iLogic form drop down, I can choose another profile from the list that is the same in Content Center and the profile will change?
HI!
More clear:
With iLogic you can "automatically " suppress/unsuppress the profiles, but you must have all the possible combinations already in your assembly, then with the drop down box you can choose the profiles you need and the rule supress the other combinations.
with Content center, it's impossible, there's no option to do that, you have to mannually substitute each member.
