Inventor Forum
Change Frame Generator Profiles using iLogic
5 REPLIES 5
1241 Views, 5 Replies
Hi, Is there a way to change Frame Generator profiles using iLogic by way of a form without suppresing/unsuppressing?
e.g. I have a frame that is 50x50x2 and using an iLogic form drop down, I can choose another profile from the list that is the same in Content Center and the profile will change?
5 REPLIES 5
CCarreiras
Hi!
I Guess not 😞
CCarreiras
What about using Content Center and changing profiles?
Regards
Damien Jovica | Business Development Manager - Check Out My CAD Blog
MELBOURNE I ADELAIDE I SYDNEY I PERTH I BRISBANE
Level 1, 407 Blackburn Rd, Mount Waverley, Vic. 3149
T: 1300 66 7263 | M: 0400 732 928
E: djovica@redstack.com.au
redstack.com.au
[cid:image008.png@01CEF0FD.8EBBFD80]
[facebook_round][linkedin_round][youtube_round][googleplus_round][twitter_round]
CCarreiras
HI!
More clear:
With iLogic you can "automatically " suppress/unsuppress the profiles, but you must have all the possible combinations already in your assembly, then with the drop down box you can choose the profiles you need and the rule supress the other combinations.
with Content center, it's impossible, there's no option to do that, you have to mannually substitute each member.
CCarreiras
CCarreiras
in reply to: CCarreiras
BTW, Supressing with iLogic will remove the suppressed members from the boom automatically.
CCarreiras
Thanks. I'm looking for a way to call out a profile rather than building master model with every profile and then unsupressing the selected one.
There are other forums threads that use iLogic and Content Center for nuts etc:
http://forums.autodesk.com/t5/inventor-general-discussion/ilogic-content-center-replace-nuts/td-p/34...
http://forums.autodesk.com/t5/inventor-general-discussion/changing-c-c-component-automation/td-p/273...
http://forums.autodesk.com/t5/inventor-general-discussion/changing-c-c-component-automation/m-p/3378...
and was wondering if it could be applied to Frame Generator or using Content Center Profiles... You change profiles manually. Is there VB code out there?
