Gots me to wondering this morning, is it possible to modify this screen? The screen comes up when editing the title block feild properties and since I dont use alot of them and I have a couple custom ones made, it would be expressly convienient to have it all on this screen (summary) instead of clicking on this tab, that tab and the other tab (so to say).
Basically asking if you can re-map these feilds?
tks!
Solved by cbenner. Go to Solution.
If you are using Vault Professional, you could use Data Cards, which are customizable in the Vault. You can set them up to show whatever properties you need. You can also check out Sean Dotson's IpropWiz software. http://www.ipropwiz.com/index.html
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
It's also possible to use VBA to make your own dialog box, run from a macro, to enter the ones you want to use instead of using the iProperties dialog. I have one, based on an example from Brian Ekins (I think). The dialog box itself is designed to look like the title block, so that I actually enter it exactly where it belongs on the drawing.
Chris, thanks I will give that add on a bash, but I dont like that it is quite expensive for just a modifier.
Jt, is this something you can share so I can try to mock it or something similar up to what I am doing? It would take most of the dumb out of it, which as I am sure you know can be a good thing 😉
Tks
Talayoe,
In principle I don't mind sharing it, but my programming skills are quite weak, and revolve mostly around cobbling things together from code found online and in the programming help file. Nothing I've done is likely to be a good example, so you're probably better off with the original example I started from.
http://modthemachine.typepad.com/my_weblog/2009/10/drawing-automation.html
The example I started from came from this post. I then modified the form, changed or added some properties, and otherwise messed with it until it worked for us.
