I like to change the dimension of the length from 388mm to 400mm to represent another similar part with another part number. Yet I still need the old part.
What is the easiest way to do so? When I use 'save as" and then change the dimension, I need to recreate the dimensions in the dwg files. Is there a way to avoid creating the dimensions?
I think I am not doing correctly.
Try using the Design Assistant.
I-Parts is a good way to go. Give it a try.
Best Regards,
Igor.
@luiww wrote:I like to change the dimension of the length from 388mm to 400mm to represent another similar part with another part number. Yet I still need the old part.
