I make a lot of holes, but I almost never use the default Linear placement. Is there a way to change the default hole placement method in Settings somewhere so that concentric is the default?
Solved by abreen. Go to Solution.
Solved by mcgyvr. Go to Solution.
Hello, I thought that 'From Sketch' was the default?
I allways put the 'point' on the sketch and Hole 'From Sketch' picks them up.
Warren.
2013 Product Design Suite Ultimate 64-bit
2012 Product Design Suite Ultimate 64-bit
2011 Product Design Suite Ultimate 64-bit
All running at the same time 🙂
Warren,
From Sketch is default when there's a sketch already present, but Linear is default otherwise. But I don't really care what the default is now, I want to know if it's customizable in options, an xml file, or the registry somewhere.
@abreen wrote:
Warren,
I don't believe so. Thats hard coded in the software I suspect.
I've found a solution for this! Even though "Linear" is the default selection, if you choose a plane and a round feature as references the program automatically switches to "Concentric"!
Thank you! This eliminates one small annoyance for me, at least if I can remember it the next time I need to use Concentric placement.
Sam B
Inventor Professional 2015 SP2
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
