Inventor Forum
CHANGE COMMAS TO FULL STOPS IN HOLE TABEL
6 REPLIES 6
BLHDrafting
2202 Views, 6 Replies
Why the hole chart has commas instead of decimal points I don't know but does anyone know how to change them? Even my VAR can't figure this out.
Brendan Henderson
Web www.blhdrafting.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2016 PDSU SP1 (Build 210), Vault 2016 Professional Update 1 (Build 21.1.4.0)
6 REPLIES 6
blair
in reply to: BLHDrafting
This might be related to number formating within the Windows O/S for country. Check: Start>Control Panel>Region and Language>Formats>Additional settings>Numbers>Decimal Symbol:
This also where IV picks its date format.
If it works, through a shrimp on the barbi for me
Delta Tau Chi ΔΤΧ
BLHDrafting
in reply to: blair
Thanks Blair. Have checked that but no go. Regular and ordinate dims are fine, as are hoe notes. It's just the bloody hoe table decimal points. As a matter of interest how is your hole table formatted, commas or decimal point? Regards, Brendan Henderson BLH Drafting Services
Brendan Henderson
rdyson
How about here?
PDSU 2016
blair
in reply to: rdyson
RBM on the Hole Table, to bring up the Edit Hole Table, at the bottom in the Column Settings, RMB on the XDIM and select Format Column. Over on the Units, in the Decimal Marker dialogue box, select .Period from the pull down menu. I suspect that yours is set to ,Comma.
Delta Tau Chi ΔΤΧ
BLHDrafting
in reply to: blair
That's the trick blair. Thanks too you and to all who assisted. That's been bugging me for 2 years! Thought I better get it sorted once and for all before we upgrade to 2013 next week!
Brendan Henderson
kahn.cad
in reply to: blair
Thanks blair. Your solution from 2013 still helping me on 2020. I just come across your prudent comment while seeking to eliminate the comma in Hole Table.
