Inventor General Discussion
Member
0 Kudos
Post 1 of 7
Change color of parts
698 Views, 6 Replies
12-23-2012 11:34 PM
Inventor pro 2013 - how do I change the color of a part.
Inventor 2012 had a menu called Color Override that I can't find now.
Alon
The biggest difference, in 2013 as it has really been split into Material and Appearance. Material will have a standard stock appearance, but contains the physical properties of the material. Whereas the appearance only contains the finish of an item.
As JD stated, they are still applied the same way.
Are you wanting to change the color of a part in an assembly, or in the part file?
In an assembly, select the part (not face or subassembly), then choose the Appearance you want from the dropdown at the top of the screen.  In a part file, with nothing selected, or the entire part selected in the browser, choose the Appearance as above.
2,129 Kudos
Post 2 of 7
Re: Change color of parts
12-24-2012 04:54 AM in reply to: alon
You can change by part, by body, by feature or by face.
Should be the same as in 2012.
Can you attach file here or at least screen capture of your browser?
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
780 Kudos
Post 3 of 7
12-24-2012 10:10 AM in reply to: JDMather
IV2015 SP1-ud2 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-980 Classified - 347.09
SpacePilot Pro 10.2.0 / 17.2.0.11011 / 4.17
Delta Tau Chi ΔΤΧ
*Pro
285 Kudos
Post 4 of 7
12-24-2012 01:45 PM in reply to: alon
Member
0 Kudos
Post 5 of 7
12-24-2012 10:40 PM in reply to: alon
Member
0 Kudos
Post 6 of 7
03-14-2013 01:58 AM in reply to: alon
Hi there
I hope it's ok to drop a remark here, instead of making yet another post.
What if the scenario is a welded assembly that ends up being painted or galvinized? I would like to select same color override option as in parts. Can it be done?
Best Regards
Morten
780 Kudos
Post 7 of 7
03-14-2013 09:53 AM in reply to: mortenrisumhansen7822
same
Win7-64
Delta Tau Chi ΔΤΧ
