Inventor Forum
Change BOM Structure with iLogic
8 REPLIES 8
Message 1 of 9
4480 Views, 8 Replies
I'm using rules to control a part that I made. This part is available in steel and wood.
But steel = normal and wood is something we have to buy.
I would like to adjust my rule so that my material choice will effect the "Default BOM Structure"
I just can't find the right "code" to start with.
I would like to do this on part level.
Thanks.
8 REPLIES 8
Message 2 of 9
-niels-
Does this topic help any?
I did a search on the forum for "BOMStructureEnum" and this seemed somewhat similar...
http://forums.autodesk.com/t5/Inventor-Customization/bom-structure-FromNormal-to-Phantom/m-p/3604844...
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 3 of 9
in reply to: -niels-
I get an error when I try that:
(translated: Bom for type PartCompenentDefinition not found)
Message 4 of 9
-niels-
This is what i could find in the programming help:
Spoiler
PartComponentDefinition.BOMStructure Property
Parent Object: PartComponentDefinition
Description
Gets and sets how the component is used/viewed in a BOM.
Syntax
PartComponentDefinition.BOMStructure() As BOMStructureEnum
Version
Introduced in Inventor version 10
 I'm not much of a programmer, so just trying to help you find what you need.
Hope this helps.
Niels van der Veer
The Netherlands
Message 5 of 9
cwhetten
Can you post your iLogic rule here?  It would be very helpful in helping us understand exactly what you need to do.  With programming, context is everything.  I think I can help you, but I need more information.
Cameron Whetten
Inventor 2014
Message 6 of 9
in reply to: cwhetten
This was the code I found.
I like to change the BOM status in the Document Settings on part level. (see attachment)
doc = ThisDoc.Document
def = doc.ComponentDefinition
thebom = def.BOM
thebomview= thebom.BOMViews(1)
thebomrow = thebomview.BOMRows(1)
thebomrow.BOMStructure  = 51971 'kPhantomBOMStructure
and this
Public Enum BOMStructureEnum
  kDefaultBOMStructure = 51969
  kNormalBOMStructure = 51970
  kPhantomBOMStructure = 51971
  kReferenceBOMStructure = 51972
  kPurchasedBOMStructure = 51973
  kInseparableBOMStructure = 51974
  kVariesBOMStructure = 51975
End Enum
Message 7 of 9
cwhetten
Try something like this:
oMaterial = iProperties.Material
Select Case oMaterial
	Case "Steel"
	ThisDoc.Document.ComponentDefinition.BOMStructure = BOMStructureEnum.kNormalBOMStructure
	Case "Wood"
	ThisDoc.Document.ComponentDefinition.BOMStructure = BOMStructureEnum.kPurchasedBOMStructure
End Select
 This should work to switch the BOM structure at the part level.  However, this rule won't automatically run when you change the part material.  You will have to do something extra to get it to automatically run.  The easiest would be to set an event trigger for "Material Change" (see the image below).
If that doesn't work, there are other ways.
Cameron Whetten
Inventor 2014
Please click "Accept as Solution" if this response answers your question.
Message 8 of 9
I got it to work.
There was no need to set the trigger. It changed every time I choose a different material. Here is my final code:
(Some text is in norwegian but Treverk = wood, Stål = staal, Rusftfritt = stainless)
If Material = "Treverk" Then
MultiValue.SetList("Diameter", "Ø 40 treverk","Ø 50 treverk")
Diameter = "Ø 40 treverk"
End If
If Material = "Syrefast" Or Material = "Stål" Or Material = "Rustfritt"
MultiValue.SetList("Diameter", "Ø 33,7","Ø 42,4")
Diameter = "Ø 42,4"
End If
If Diameter = "Ø 42,4" Then
diameter = 42.4
ElseIf Diameter = "Ø 33,7"
diameter = 33.7
ElseIf Diameter = "Ø 40 treverk"
diameter = 40
ElseIf Diameter = "Ø 50 treverk"
diameter = 50
End If
If Material = "Rustfritt" Then
thickness = 2
rm = 74
iProperties.Value("Project", "Stock Number")= "RF RØR " & diameter &"x"& thickness
Feature.Color("Sweep1")= "Stainless - Brushed"
Feature.Color("Sweep2")= "Stainless - Brushed"
Feature.Color("Sweep3")= "Stainless - Brushed"
iProperties.Material = "AISI304"
ElseIf Material = "Syrefast" Then
thickness = 2
rm = 74
iProperties.Material = "AISI316"
ElseIf Material = "Stål" Then
thickness = 2.6 mm
rm = 74 mm
iProperties.Value("Project", "Stock Number")= "RØR " & diameter &"x"& thickness
Feature.Color("Sweep1")= "Turquoise"
Feature.Color("Sweep2")= "Turquoise"
Feature.Color("Sweep3")= "Turquoise"
iProperties.Material = "S235JR"
ElseIf Material = "Treverk" Then
thickness = diameter/2-1
rm = diameter/2
iProperties.Value("Project", "Stock Number")= "Treverk " & diameter
Feature.Color("Sweep1")= "Wild Cherry - Groove"
Feature.Color("Sweep2")= "Wild Cherry - Groove"
Feature.Color("Sweep3")= "Wild Cherry - Groove"
iProperties.Material = "Wood"
End If
If Bend = "1 bend" Then
Feature.IsActive("Sweep2") = False
Feature.IsActive("Sweep3") = False
Kapp = Topp + Skrå
ElseIf Bend = "2 bend" Then
Feature.IsActive("Sweep3") = True
Kapp = Topp + Skrå + Bunn
ElseIf Bend = "2 bend paralel" Then
Feature.IsActive("Sweep2") = True
End If
    Case "S235JR"
    Case "AISI304"
    Case "AISI316"
    Case "Wood"
End Select
Message 9 of 9
cwhetten
Excellent!  I'm glad it worked for you.  I see that you are using a user parameter to select the material.  By default, iLogic rules will run automatically if a parameter that they contain changes value.  So that is why it automatically runs for you without the event trigger.
Using a user parameter was going to be my second suggestion in lieu of using event triggers.  Smiley Happy
Cameron Whetten
Inventor 2014
