Inventor Forum
Change Base Quantity in family template in Content Center
4 REPLIES 4
tegstette
1055 Views, 4 Replies
Hi
I need to change the Base Quantity of family templates in CC from GL = ... to Each. (I know there are several different qty, but I need this to Each because of ERP-system).
I use open from CC and place a tube in an iam, and changing BOM-settings to Each on that tube.
Then I replace template in the family in CC editor with this file. And everything seems OK.
When I use "Place from CC" and place a tube from this family, everything is in perfect order. The ipt has Base Quantity set to Each just like I wanted.
BUT .... (!)
I use Frame Generator and insert tubes from this family, then the Base Quantity "bounce" back from Each of GL = ...
I need this to work also in Frame Generator.
Anybody have any solution to this?
MVH
Tore
Best regards
TG
Autodesk Inventor/Vault Professional 2021
4 REPLIES 4
hugo.trepanier
in reply to: tegstette
If you need to do this you will need to replace the familly template.
Follow this:
1) Copy your family to your read/write Library in the content center Editor
2) Generate a steel shape from this library (just create an IPT file with any length, is not important)
3) Open this ipt and change in the document settings, under Bill Of Materials, the base qty to each instead the GL
4) Save this file
5) Go to the content center editor
6) Make sure that your library view is only on your read/write lib
7) Right click on your family
😎 Select Replace Family Template
9) Chose your ipt previously generated and updated with the new base qty
10) all is done :)!
I hope that this procedure will be helpful!
Hugo Trepanier
Autodesk MSD Application Specialist
tegstette
in reply to: hugo.trepanier
Thank you for your answerSmiley Happy
This is how I have done it, but it does not work. I am informed that Autodesk developement are looking into the problem.
Have a nice daySmiley Happy
Best re
TEG
Best regards
TG
syjolain
The issue is still there for Inventor 2019
Do you plan to fix this ?
johnsonshiue
in reply to: syjolain
Hi! I am not sure if your issue is the same as the original thread. Do you mind starting a new thread and elaborating the problem?
Many thanks!
Software Test Engineer
