Inventor Forum
Change Active Ipart with Ilogic Form
3 REPLIES 3
jpinda
1962 Views, 3 Replies
Dear Everyone
I have an Ipart I would like to have a Ilogic form to change the active Ipart.
I tried iPart.ChangeRow but I did somthing wrong and it doesn't work.
I have no clue on what I am doing But no have to learn some way
3 REPLIES 3
MjDeck
in reply to: jpinda
Here's a sample iPart that shows how you can use an iLogic form to select a row in the iPart factory.  It has a Text parameter named ActiveRow, and this drives an iLogic rule. This is the rule:
iPart.ChangeRow("", ActiveRow)
(The "" or empty string is required. In an assembly, this would be the name of the component. For a rule in the iPart factory itself, use an empty string.)
The part also contains an iLogic form that drives the ActiveRow parameter.
Mike Deck
Software Developer
Autodesk, Inc.
jpinda
in reply to: MjDeck
I don't know why I could not get it.
Thanks so much works great.
Later
kamalesh.vasudeva
in reply to: MjDeck
I struggled with this for over 2 days. Figured out just now from your post. Thanks. Inventor online help needs update on the matter.
