Does anyone know how to change a tapped hole from being tapped through (tapped through hole) to being a tapped blind hole with dimensions for the tap drill depth and thread depth using iLogic or A.P.I.?
I would like to be able to switch back and forth between the two different types of tapped holes (through & blind), per whatever is required by the iLogic .ipt that is generated by user inputs.
Does this make sense to anyone?
Solved by Curtis_Waguespack. Go to Solution.
just a quick link to the other thread:
