Inventor Forum
Chamfered holes in sheet metal
2 REPLIES 2
429 Views, 2 Replies
When I flatten a Sheet Metal part with a Chamfered/Countersunk hole in
it the flattend part shows the through hole as the diameter of the
Chamfer/CounterSink. This get tranfered to my tuuret. This is bad.
Is there something I can do to prevent this?
Craig Nunn
2 REPLIES 2
As I remember by picking different faces or even the opposite side of the part you can
minimize it. I think there is still cases that get through no matter what you do though.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Craig Nunn" wrote in message
news:D2CA206CC0E3E5184FDC9AF4DB6E63A9@in.WebX.maYIadrTaRb...
> Craig Nunn
If you just want to view the flat that works fine if you have a chamfer
on just one side. Ordinarily to get anything useful from the flat you have
to export it. In my case "dxf" for use by an automatic nesting software.
When you do this you don't see anything but the Csink Diameter. If you open
the dxf in autocad the geometry for the actual hole is not there.
Craig Nunn
"Kent Keller" wrote in message
news:393A1BCDEC69C386165174027FD44E98@in.WebX.maYIadrTaRb...
part you can
what you do though.
> Kent
> Assistant Moderator
in
> > Craig Nunn
