Inventor General Discussion
Valued Contributor
richard_cirillo
Message 1 of 3 (247 Views)
Accepted Solution
chamfer won`t work
247 Views, 2 Replies
12-18-2013 03:36 AM
I am trying to place a 5mm chamfer along edge so as it meets the cylinder....i cannot get it to work on this model but on an exact other model i can place a 5mm chamfer...am i missing something here
thanks
Inventor 2013/Inventor 2014
Hi!
The question is; you have two different distances, and somehow, Inventor has issues split/merge the face between these two distances when you apply chanfer (between extrusion and revolve).
Workaround:
  1. Create the extrusion as a new solid (now you have two solids; multisolid part)
  2. Create the chanfer with the distance you need in the second solid: extrusion.
  3. Use "combine" to join the two solids... and that's it.
Check the attached part.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
Distinguished Mentor
ccarreiras
Message 2 of 3 (230 Views)
Re: chamfer won`t work
12-18-2013 04:33 AM in reply to: richard_cirillo
Hi!
Workaround:
Regards.
CarlosC
Autodesk Inventor 2014 Certified Professional
Autodesk Factory Design Suite Ultimate 2015
Windows 7 64Bit
Valued Contributor
richard_cirillo
Message 3 of 3 (221 Views)
12-18-2013 04:55 AM in reply to: ccarreiras
Thank you Carlos
Announcements
Need installation help?
