I am trying to place a 5mm chamfer along edge so as it meets the cylinder....i cannot get it to work on this model but on an exact other model i can place a 5mm chamfer...am i missing something here
thanks
Inventor 2013/Inventor 2014
Solved by CCarreiras. Go to Solution.
Hi!
The question is; you have two different distances, and somehow, Inventor has issues split/merge the face between these two distances when you apply chanfer (between extrusion and revolve).
Workaround:
Check the attached part.
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
