Inventor General Discussion
Valued Contributor
j_berry
Message 1 of 5 (645 Views)
Chamfer set length
645 Views, 4 Replies
01-17-2013 01:59 PM
I searched and found numerous topics on this issue, all of them over 3 years old, so I guess it might be worth asking again.
I'm wondering if there is any way to chamfer a set length along an edge (similar to what can be done with flanges in sheet metal mode), as opposed to the entire length of an edge.
Hi j_berry,
You might have found this link in your searches, but if not there is an example file attached there that might help:
http://forums.autodesk.com/t5/Autodesk-Inventor/How-to-stop-chamfer-before-the-corner/m-p/3275375
And here is the link from that page that seems to have changed:
http://cadsetterout.com/inventor-tutorials/ifeature-stopped-chamfer/
You might also post your improvment idea to have an option to have it work like a sheet metal flange here:
Inventor IdeaStation
I hope this helps.
Curtis
Curtis_Waguespack
Message 2 of 5 (643 Views)
Re: Chamfer set length
01-17-2013 02:08 PM in reply to: j_berry
Hi j_berry,
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
blair
Message 3 of 5 (620 Views)
01-17-2013 10:54 PM in reply to: j_berry
No, due to the nature of the fillet algorithim, it would know how to deal with the start and end face on the chamfer.
You would need to create a work plane and sketch using the Extrude-Cut
IV2015 SP1 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 344.60
SpacePilot Pro 3.06.109
Delta Tau Chi ΔΤΧ
Distinguished Contributor
VdVeek
Message 4 of 5 (607 Views)
01-18-2013 01:11 AM in reply to: blair
Is the nature of a fillet algorithim different then a fillet? Because in a fillet it's posible. In the fillet option you can create a variable radius by placing points and change the radius to zero. Why not use this for a chamfer?
Rob.
Autodesk Inventor 2015 Certified Professional & Autodesk Inventor 2012 Certified Professional.
Valued Contributor
j_berry
Message 5 of 5 (596 Views)
01-18-2013 05:19 AM in reply to: Curtis_Waguespack
Curtis_Waguespack wrote:
Hi j_berry,
No, that topic had not come up in searches. A similar topic on that second link was exactly what I was looking for - the stopped chamfer with curved ends (Lark's tongue chamfer - http://cadsetterout.com/inventor-tutorials/ifeatures-larks-tongue-chamfer/ ). Thanks!
