Troy, if you needed to make such a thing, I found a couple of ways to do it.
Since the chamfer is applied differently between the "entry" edge and the
"exit" edge, you can create a hole from each side so you have two entry
edges, or extrude cut both ways from the center plane to get two exit edges.
Workaround, though- shouldn't be necessary.
Sam
Eli Lilly and Company, Indianapolis
"Troy Grose >" <"mount_mordor ATbITTmEsPAM Hotmail DOT com">
wrote in message news:5026275@discussion.autodesk.com...
Well it's a good thing I really don't have to make the chamfer like
that, but boy it's not good when IV can't seem to solve what I think is
a pretty simple part:~/
JDMATHER wrote:
>> (going from discussion, can't see part).
> Here ya go. I added a hole with revolved cut "chamfers". The other hole
has chamfers made as one feature (it doesn't matter if done with one feature
or two - the results are the same, that is the chamfers solve differently)=
